I found this article on Rubicon Owners Forum and though I would copy it here just incase anyone is interested.
As we all know the TJ HVAC selector automatically engages the AC compressor when the first three (AC) and last two (defrost) options are selected. Take control of the AC with just a SPST switch!
Here is what I did. On the back of the HVAC control there is a three pin connector on the far right with a black wire (ground), dark green (to fan speed control) and lightgreen (ground to PCM when AC or defrost is selected)... the light green one is the one we are headed for. Simply install a switch on that wire. Then YOU can control the AC.
I installed mine on normally open (NO) contacts.. When AC or defrost is selected I will push the button to engage the AC compressor. I did that because I rarely use the AC and I don't always want the AC to run in defrost. I can also use the bi-level select (third AC select) for heat without the compressor running.
Another option is connect normally closed (NC) contacts. AC compressor runs unless you deselect it. I would have done it this way in a high humidity climate where I used AC more.
I used a latching push button switch installed right on the HVAC control. The white and blue wires from my switch are my common and NO contacts. The others are for illumination I wired to the instrument lights and the NC contact not used. Any SPST switch can be used and put anywhere the user wants.
Most of these pics are of my switch install and have nothing to do with the actual intent of the mod. I was just pleased how well it turned out.
