Hi, I upgraded my all my lights (front, turn, fog and rear) with LED lights. Looks great, great output too. Because LED has less resistance, the OEM flasher assumes a rear light is broken, and flashes the turn signals at like 4x speed. So I installed a LED flasher, which solves the problem, so turn signal blinking is back to normal.
So far so good.
However, when I turn on the hazard switch, the LED flasher goes berserk and flashes at like dozens times per second.
Does anyone have had the same experience and found a solution?
I ordered a second LED flasher but it does exactly the same, so I ruled out a defect flasher.
Also checked all the wiring, and all lights function as they should and ground wiring is fine too.
I’m thinking about several solutions:
1) Find a LED flasher that also does normal hazard lights (if it is available at all)
2) Replace the hazard lights switch which supports the LED flasher (if it is available at all)
3) Add a resistance to the rear light wiring to mimic the old school lights, and install the old OEM flasher (which is quite the bit of work)
Thanks for the help. This forum has been great so far.
So far so good.
