Headlight, tail light, and dashboard issue
MajiJeepTJ
Queens
Hi, hope everyone is doing well after these past few weeks of storms. I have an issue with my headlight, taillight, and cluster lights not turning on at the same time. I was driving about two weeks ago and my cluster lights when out. I heard a buzz and the cluster lights went out, my headlights did not. I did not realize that my tail lights were out too. If I pulled the headlight switch out all the way headlights go on but the cluster or taillights do not. If I pull it out a certain amount the cluster lights and taillights go on but no headlights. I ordered the Standard Motors DS357 Headlight Switch and that did nothing. I then bought another one thinking it may be defective along with the Standard Motors HP4195 headlight switch but the bottom part where it is all wired up. I wired everything up and installed the new headlight switch. Still the same thing is happening. I checked all the fuses and everything is good. Any ideas?
Did you figure this out?! Because I have the same issue. Headlights were not staying on so I swapped the switch and now nothing but headlights comes on unless I pull it just a touch from 'off'. Then dash and runners and brakes come on briefly. Dash and tail/brakeights are a no-go in 'full out' position.
Was gonna swap connector til I read your post.
