I think I’ve found the problem. I believe it’s the AC, vent, floor, defrost switch. I heard what sounded to be a vacuum leak and moved the switch to floor. The leak stopped but then the switch wouldn’t change settings anymore. The knob just turned smoothly without clicking from setting to setting. I looked for a new panel and noticed the prices are all over the board. I’m assuming the Cheaper ones are probably going to go bad quickly, mainly because that’s my luck, and the OEM are rather pricy. The other switches, (fan & heat/cold), work fine so I was wondering if it’s possible to just change out the bad one.
Thanks.
Thanks.
