Just bought some Hella 500 Black Magic lights for my 2005. From what I gather, the wiring harness is not as simple as some other lights offer, and the instructions are pretty vague. That said, I was reading through the installation guide, and I came across a few things that I hope someone can shed some light on. I have a very basic understanding of the electrical system - I wired my own rock lights, and installed my own fuse, but they were really easy to do. I've wired my own CD players, etc. before - but beyond that, I'm a novice. I just want to make sure I understand what's going on before I get too far into these things.
1) I want these lights wired so that they are only on when I flip the switch (I don't want them on when I'm using my high/low beams). Does that mean that I need to ignore the 3rd wire that runs from the switch to the headlamp? In simpler terms rephrase - how do I wire the lights so that they only come on when I intentionally turn them on via the switch?
2) The 12V+ power for the switch sort of confuses me. From what I understand, that is how the switch actually gets power when the vehicle turns on, so it needs to be wired into a 12V+ power source, right? Where/how do I find a 12V+ power source? Once I find locate where I want to pull power from, do I just splice the new wire into the existing ones from that power source? For example - if I want to pull the power from the power outlet on the dash, would I just remove the existing wiring from the outlet, splice my new wire/existing wire together, and then reconnect it to the power outlet?
