I noticed a clunk when making hard turns n hitting bumps. When I accelerate left side comes up.
Will the bad bushings cause the left side to lift when accelerating. If I put in reverse the left side goes down. This happened when switching gears too if I give it a lot of gas
If the bushings are cooked then the sway bar is literally flopping in the breeze and can move in any direction.
Spend the extra $75 and get quick disconnects if you replace the links. Those bushings on the upper ends fail with some regularity, and you'll probably want to disconnect the sway bar at some point. If you have the need and the coin, look into the Currie Anti-rock.
It seems that you have something else going on. Unless that bushing was completely missing, I can't see that being the cause of your left side 'going up' or 'going down' upon acceleration or going over a bump. It seems something else is loose, broken, or missing a bolt. It might be the swaybar link, but again, unless that is broken, I don't see that causing what you are describing...
If you'er suggesting what I think you are I think it's a bad idea to get under a running vehicle while in gear.Lift and suspend your jeep up and try to run (low gear) it like you are driving turning the wheel left to right with someone below, a mechanically inclined person watching underneath. That might help figure out the loose stuff in your suspension/steering/drivetrain mechanisms.
Revisiting this thread I started. So after my disconnects install the knocking issue went away but I’m still experiencing the left side lifting up when I let out the clutch and give it gas. If I put it in reverse the left side drops a bit. If I’m in second gear and tap the gas I can see my driver side lift up. What’s the deal?
