I recently removed my 97 tj tub and put a 01 tj tub on. I used the 97 engine bay wiring harness along with the engine/pcm. On the inside I used a 01 wiring harness. I turned the key over and engine fired up but cluster isn't working. Could some please help with my issue. I have read that 97 to 00 TJ used a CCD bus and a 01 to 06 used a PCI bus. Any input would be greatly appreciated.......thank you!
