Hello all. I have a 2004 Jeep unlimited 4.0. I just did the ball joints, u-joints in the front axle shafts, and the wheel hubs. Went to put the axle shafts back in and when I tighten the axle nut it is slightly backing out the axle shaft. So then when you turn the hub on one side the other hub doesn’t turn anymore like it should. The front driveshaft will turn but the opposite hub doesn’t turn. We’ve tried re-seating the axle shafts and nothing is working. Even put the old wheel hubs back on and it still does it. Any ideas what I could be doing wrong?
