You can sneak a wrench in from the driver's side. There is an opening that it will fit through. Get a box end in there and then hit the bolt with an impact to break the bolt. You want it to break next to the nut or it gets to be a real bitch to get out.Hello all changing out the front track bar and the flag broke off the nut! Any suggestions?
It is. He has to pry the bits of the flag off so the wrench will grip.I think its a 15mm nut
The nut choice had nothing to do with it loosening. That was nothing but improper torque.I went to the dealer and bought a replacement after I broke mine. We initially used a nut during the reinstall but that was a poor decision, it loosened up on the highway.
Don’t disagree with you, just had trouble torquing the non-flagged nut down.The nut choice had nothing to do with it loosening. That was nothing but improper torque.
Sacrifice the bushing and cut into the rubber, through the bolt sleeve and bolt to save the mount. Replace bolt and bushing.Aside from hopes and prayers, what is the procedure for locating the break next to the nut?
The tab holds it so you don’t have to get a wrench on it. View attachment 83695
oh, ok, did not know it had an official name. Mine just has a regular nut.
