Short version: Are hex rivets supposed to sit loosely in the hole before your tighten the bolt?
Hey gang. I have a 2004 X which I keep the doors and top off all summer. I just got an Instatrunk (IT hereafter) to keep the back secure since there is only the glovebox and center console to lock things up when I leave it parked anywhere.
There are existing hex holes with rubber plugs in the sides of the area behind the rear seats that the IT is designed to utilize. The IT came with hex rivet nuts to insert into the existing holes into which the bolts will thread to hold the IT in place. It came with a tool that I think is used to pound the hex rivets into place. The hex rivets, however, slide easily into the existing holes (once I pulled out the rubber plugs) and sit there very loosely, falling out when I take my finger off them.
I have never used hex rivet nuts before and the instructions that came with it suck. The internet says the collapse when the bolt is tightened, kind of like a wall anchor you use in drywall.
My question is: are they supposed to be so loose or are the hex rivets too small?
Long explanation for a simple question, sorry.
