High Beam Light Indicator Not Working
sublime5o
Buffalo, NY
My high beam light indicator is not turning on anymore. I am assuming I need to replace the dash light for it. My question is, I see there are kits that are all one color but do I need to get individual color lights for each indicator (high beam is blue, check engine is orange, etc)? Anyone have a link for a kit they suggest?
The high beam logo is colored blue. So a white bulb will still show blue.
I replaced mine years ago with an LED. It was blindingly bright when on. I had to search for the lowest power LED bulb I could find to keep it around the same brightness.
The color is determined by the plastic of the dashboard itself, which is blue for the highbeams, green for the turning signals, etc..., so most lights won't change the color of the indicator.
(Though one time I put a really bright red led on the high beams indicator and it did look kinda funky. But since most kits are white –or at least the most common– you won't have that problem)
