The headlights in my 2003 TJ won't come on, but the high beams will. With the multi-function switch in the headlight position both the tail lights and dashboard light up so I don't think it's a switch issue. I know that's a common problem, but I'm not sure replacing the switch should be plan A here. The side marker lights also won't come on, unsure if this is related.
The high beams are pretty dim so I can drive around without blinding anyone, but I'd like to get this figured out now that it's getting dark earlier. Any suggestions/ideas would be appreciated.
