Hello everyone I’m in the process of changing the gears on my Dana 30 hp to swap into my TJ. I have a quick question this is my first regear and would like to ask if my contact pattern looks good. This is a used gear set so I realize the pattern isn’t going to be perfect. These are also my set up bearings so it will probably change a bit when I press them on. Thanks in advance.
Ethan
Ethan
