Cuttin" it close, but it looks like you might be on schedule to have her ready to run the winter ALCAN?
Where wiring will be routed close to the exhaust I depinned connectors and sleeved them in DEI heat sleeving (DEI 10916).
This video shows how to depin many different connector types:
Wise choice, Tox. I also covered all my wiring that was anywhere near the exhaust. Crazy amount of heat there. I was able to get away with not pulling any connectors by using big enough sleeves, but yours will likely look a bit more finished. Nice work.
Thanks for the kind words!
Thinking about it, I had one of those hard plastic hole plugs in the frame near the passenger header melt - and it was farther away from the header than the wiring. All the wiring has been fine in their cozy little sleeves - so it was definitely worth the effort.
My headers are ceramic coated, which is supposed to help a bit with heat transfer, but they still get pretty damned hot.
I've been thinking about getting mine coated too along with the pipes.
They definitely look cool (see what I did there?), but you know - Hemi. Not sure how they will look with all of your spark plug wires sticking out.I've been thinking about getting mine coated too along with the pipes.
Seriously though, 4 years later they still look like this.
My headers & Y-pipe are ceramic coated. I'd thought about doing more of the system but decided not to.
This writeup was pretty informative too, I would have gone with the FTZ tool, but it was out of stock when I was looking.
https://marinehowto.com/making-your-own-battery-cables/
This is really great information! Thanks for sharing it!
Guess I need to read it so I don't overcrimp mine. I've got to build all new cables for mine.
He hit on a lot of the frustration I felt with my hydraulic crimper from Amazon.
I got mine from Amazon also.... We'll see how it does. I might end up buying a NEW tool.
Unless you like spending lots of money, you're going to want to buy an OLD tool. AMP Rotacrimp, T&B TBM8, and other industrial grade tools are $1500+ new, but there's several on eBay right now for significantly less. Just make sure you know what you're buying and that it has all the dies you will need if it uses dies.I got mine from Amazon also.... We'll see how it does. I might end up buying a NEW tool.
