- Joined
- Nov 29, 2015
- Messages
- 235
First let me say that if you are planning to purchase Smittybilt or Rugged Ridge hood locks please don't!
I purchased a set a couple of years ago and of course both sides failed when I needed them most. I was returning from a 550 mile trip when I noticed that my driver's side pin wasn't locked and the hood was fluttering. This was 5 miles into my trip. I stopped and relocked it. Another mile it was open again. The lock failed. I had no other means of locking the hood as those pieces of shit replaced the factory hold downs. 50 miles later the nut plate on the passenger side that holds the pin to the fender fell off rendering the lock useless. All I had holding the hood down was the factory center release lever. I couldn't drive faster than 45 miles per hour due to the hood flying into the windshield fear factor. A 9 hour drive took me 14 hours. Rant over...
I decided on brainstorming another method to lock the hood but not eliminating the hold downs. Fortunately I had a set of old school spring loaded hold downs I was able to temporarily install until I can dig up the new rubber OEM set I have stashed away but don't remember where.
The idea I came up with was to buy a pair of tube key cam locks locally and go from there. Cam locks come in different cylinder lengths a I bought 1 1/8" so as to clear the lip under the hood. Cost of the 2 locks was $10.00 USD. If I purchased on line I would have bought 2 black locks keyed alike. Mine use different keys.
Toughest part of the job was fabbing a custom eye bolt for the fender. You can see my first 3 failed attempts. One side is done. I'll finish the other side later.
When I have both done I'll remove them and slap on a coat of black paint.
When the cam lock is in the locked position against the rubber pad on the fender there is absolutely no movement of the hood either up or down. Now back to work.
