In hot weather, once the Jeep has warmed up, my clutch squeaks on the way in and on the way out. Sounds a bit like steering column boot squawk.
I had someone pump the clutch pedal while I was underneath, and the sound seems to be coming from the clutch itself, not from the pedal. I checked the master cylinder and it appears to be filled to the brim. Any advice?
- @NKlekas: This thread is old, but it looks like you've been active lately. Did you get it resolved?
- @Rich1961, @bluescapegoat, you all recommended replacing the slave cylinder over here. Does this sound like I have the same issue?
- @Viking Jeeper, I read from @CharlesHS over here that you may have had the same problem?
