2006 TJ, Last summer I completely redid the cooling system per the guide here (new hoses, radiator, water pump, fan clutch, T stat and housing), with no cheapo knockoffs. I'd had no issues, and hadn't noticed any leaks.
Today I'd driven home from work, and went back out to meet someone. While I was waiting in the lot, my check gauges light came on and my temp was up. So I popped the hood, let it cool for about 20 minutes and made it home. I didn't see any leaking or any residue on anything (my old water pump was leaking pretty bad). The only thing I noticed off hand was that the coolant overflow reservoir looked a bit low.
When I left I was waiting at a light and started seeing the temp gauge creep up a bit, but once i was driving it came back down to normal. I also popped the hook with it running and the fan is spinning.
Right now I'm waiting for it to cool down so I can check the level in the radiator.
So if the coolant level in the overflow tank is a good indication, i'm probably just down some fluid. How would I go about finding where i'm losing it though? There's really no obvious leaks (no puddle at home, no dripping, no dried coolant caked on anything I could see).
