How much does my completely stock, 2003 TJ weigh?
My '03 Rubi weighed 3700 on truck scale, 6 cyl, manual, winch, soft-top, 33 x 12.5 x 15s, steelies, no spare, curb weight. I've heard Rubis weigh 300 lb more than Sports? Factory brochure says 3418, factory likely shows dry weight.
Reactions: NashvilleTJ
I weighed my previous TJ with aluminum wheels, RE long-arm suspension, basic armor including steel corner guards in the rear, steel rocker guards, and aftermarket steel bumpers and it was an even 4100 lbs. on a truck scale. I don't recall if it had a hard top on that day but probably not.
Reactions: Kenneth G Zinis
Hard to think of where the 300 pound difference would be. The 241 and the front Dana 44 center section plus the locker pumps probably amount to a third of that. I could see maybe a hard top Rubicon vs a soft top sport.
I realize it's been nearly two years since the last post in this thread, but I just recently weighed my '03 TJ Rubi, so I thought I would add a data point just for fun...
3750 lbs with soft top, including half-doors with soft uppers, spare tire, but no back seat. My only added armor is a Savvy gas tank skid which is a negligible increase over factory weight. My only other "added" weight would be the LT285/75/16 GY MTRks vs the original 245s
I realize this is a nearly two year old thread, but I just recently weighed my '03 TJ Rubi, so I thought I would add a data point just for fun...
3750 lbs with soft top (including half-doors with soft uppers, spare tire, but no back seat. My only added armor is a Savvy gas tank skid which is a negligible increase over factory weight. My only other "added" weight would be the LT285/75/16 GY MTRks vs the original 245s
5000 lb at loves scale with gear- full tank 1 full Jerry can and engine-t/t skids (yikes)
  • Wow
Reactions: Wildman and Rickyd
I weighed my '98 Sahara back in 2019, completely stock and with both the hardtop and softop (and the softop windows in the cab), with a full tank of fuel and my tool bag in the back. 3383.65 lbs.
loves scale
is this a thing at just any random Loves location? I might pull into one in the next week and roll across the scale.
last weight I got was on my way into the metal scrap yard with the back seat area full of heavy steel parts that had no resale value.
Reactions: ColoJeep
Yes if you go to a loves truck stop,if the scale is empty just pull on it and get out and there is a speaker there and just press the button and she’ll tell you to pull around and she will charge you 10 bucks and give you a slip with your weight.
Reactions: freedom_in_4low
