I purchased smittybilt pn 76793 tube doors for my TJ. They came with mirror mounts, no mirrors, and the mounting holes in the smittybilt brackets were drilled backwards.
I had already purchased a set of doorless mirrors from Quadratec, they are nice, and slip in where your top door hinge pins goes on the Jeep. Part # 13111.0401
So I got the idea of using Jeep TJ oem lower door hinge bracket mounts to hang the mirrors. Bought a pair of rampage off eBay, pn 7607 for $9.93 shipped.
These worked out great. You could mount them a couple different way to get height needed. I had to use a die grinder, and "egg" oblong one hole on each bracket to get it to align with the corresponding door hinge holes. Depending on your doors, this will/may vary. You could even weld them on.
The washers covered up the oblong lower hole, so it can NOT be seen after mounted. No door bushings were included for the brackets, so you will need to order (2) bushings.
Overall I am very happy with how this turned out, cost was cheap, and I can remove the mirrors with one bolt and run them doorless as well.
