To all,
I need to remove both drive shafts to do some seal replacing in the transmission and x-fer case. I know how to disconnect the shafts from the diffs, but when I try to pull the shafts away from the x-fer case, they do not budge. Are they just stuck and need some hammer action, or am I not doing something I need to do? Everything is stock with them. There appears to be a rubber boot of some sort, and a metal brace where the shaft meets the x-fer case, again, it is stock. Thanks for any help.
Edit: it is a 2001 stock TJ with the auto transmission and regular x-fer case and 4.0.
