This sort of thing comes up often but I've never really seen any sort of diagnostic process documented. We like to blame sensors for all sorts of things, and if you're like my wheeling crew, you keep a spare set on hand and then just replace them willy nilly whenever your poopbox isn't running right. So I figured it would be helpful if we actually had a process to test as many aspects of these sensors as possible. We can't test everything because we don't know everything. Like we might validate that the camshaft position sensor (aka CMP) is producing a periodic pulse, and we can even measure the duration of the pulse, but do we know how long a pulse the computer is expecting? Stuff like that. So let's get to testing what we can actually test and not worry about the stuff we can't.
The hardest part is knowing what the pinout is for your year, and then being able to use your expert spatial reasoning to figure out which pin on the sensor maps to which cavity in the plug. It's also fun to see the variation in FSM graphics over the years.
1997, 5V supply in cavity 1, sensor signal in cavity 3
1998-2004, 5V supply in cavity 3, sensor signal in cavity 1.
2005-2006 changes back to the 1997 configuration with the 5V supply in cavity 1 and the sensor signal in cavity 3. Why these things needed to change, I'll never know.
Bench Test
Many of these sensors operate on a +5V reference supply supplied by a specific pin on the PCM. If you have the sensor out of the jeep, you can test it with a phone charger & a sacrificial USB cable (or a USB to red/black alligator cable which you can get off amazon for a few bucks): https://www.amazon.com/dp/B09PQFCJJ3?_encoding=UTF8&psc=1&ref_=cm_sw_r_cp_ud_dp_QBYMFRBS9K0YD698TKBC
+5V Supply Test
Verify you get 5V at the connector by turning the key on (engine off) and sticking a probe in the 5V supply cavity on the connector, and then grounding the voltmeter at the negative battery post (or other good ground).
CMP Signal Continuity Test
The CMP signal goes from the sensor to PCM pin A18 (except for 2005 & 2006, which are on PCM C34). Check for 0Ω or continuity between the sensor signal cavity and PCM A18.
CMP Ground Continuity Test
The CMP ground comes from PCM pin A4 (except for 2005 & 2006, which are on PCM C27). Check for 0Ω or continuity between the sensor ground cavity and PCM A4.
CMP Running Signal Test
This is the fun test because I got to use a tool I hadn't used since college: an oscilloscope. I got this Arduino based oscilloscope off Amazon for $33. It came with the power supply & a BNC connector with red/black alligator clips on it. The instructions were lacking, but I was able to calibrate it eventually.
Bench Test
- Connect the 5V supply (+) to the 5V supply pin on the sensor
- Connect the 5V supply (-) to the sensor ground pin
- Connect the voltmeter (+) to the 5V supply (helps if you use alligator clips to extend the sensor pins out in the open.
- Connect the voltmeter (-) to the sensor signal pin
+5V Supply Test
- Oscilloscope red to back probe on sensor signal wire. This back probe was a challenge to get in, and you should probably do a continuity test on the corresponding cavity to ensure you actually have the probe in place.
- Oscilloscope black to chassis ground
- Start the jeep.
