Replaced my rear wheel studs on both sides today with longer ones. Thought it went well, but when I put the drum brake hub (not sure of what the real name is), I noticed the wheels would spin about halfway then get stuck, almost as if the brake is engaged (I checked emergency brake and that’s off).
With the brake hub off, everything spins freely. I didn’t take notice of what they did before I took it apart, but with both wheels off the ground, is it normal for it to stick like that or should it spin freely even with them on? Any advice?
