Hi,
I've been running my mom's old 99 TJ while my F150 is in the shop and would like to fix a few odds and ends for her as a thank you. One thing at the top of my list is to get her HVAC back going strong (south Alabama summers are brutal). I've done a bit of research and have found that there is a connection between cruise control and vent selection (a common harness I believe?). Her cruise control will turn on (light comes on the dash) but will not activate.
Does this mean I am likely going to need to replace that common harness? Does anyone have a part number on that harness? Is it a relatively easy job?
Side note, she had all kinds of ignition trouble and has had people all in the steering column working on that. However, I believe this problem pre-dates the ignition issues.
One other question, while they were working on it they lost a lot of the screws for the dash and door panels. Does anyone know of a kit I can buy with replacement hardware?
Thanks!
Thanks!
