HVAC is making a loud rumbling noise
Deitz06
New Jersey
Whether it’s A/C or Heater, when I turn it on it’s making a loud, low sounding rumbling noise? Wondering if anyone knows the solution if they had it before. I have 2006 X Sport Wrangler
Does the noise change with the fan speed? If so pull out the fan motor/blower and give it a spin and see if the bearings make any noise. It's super easy to remove in the late TJs. Just crouch under the glovebox, lift one release tab, and twist
Reactions: Deitz06
I wish I could answer that but that’s another problem I have to address. My fan speed is stuck on high. So I have to fix that. But I will give that a shot and see how that works. Thanks!
blower resistor is most likely the speed problem
That’s good to know. Thank you. I was thinking it was something to do with the wires or if I had to replace the whole fan switch.
Hopefully you just have some leaves or maybe a mouse nest in the blower motor. Just keep your fingers crossed there's no actual mouse stuck in there
Fan speed is likely the blower motor resistor. But I'll bet the fan is probably going bad as well. As the motor goes bad, the current goes up which shortens the life of the resistor
In my 2001 TJ, the noise gets louder as I turn up fan. We are not just talking ticking but a severe loud rumble.
Is the process the same to check the blower? Easy?
