Check the bulb and the connection at the bulb and at the door plungers, also be sure fuse 4 is in good -
It is more likely there - if it is all the inside lights, or if they are off and flicker on, I would lean toward the multi function switch, which is essentially the turn signal stalk- just remember if you save it some parts transfer from your old one to it.
Good luck, keep us posted.
