Hello , I too have joined the vibration club. I lifted my 2004 tj 2.5 inches and replaced the shocks with rancho 5000x per all the recommendations here. Also new 33s and wheels. The jeep rides and drives better than stock. After the lift I had the typical vibes at low rpm acceleration , dropped the T-case/ skid , cured those vibes. I never drove it over 45mph until after I did the t-case drop. Now I take it out , get up to 50mph and above and get vibrations. I removed the front drive shaft and the vibes go away . I sent my front drive shaft to a shop that does all our fleet drive shafts here at work and they say its fine . Now for my question, if the drive shaft is fine should I go to adjustable C/As in the front and fine tune the angles , upper or lower? This is street queen only .
