Alright here are the problems I’m running in to. About two months ago the 4.0 engine I have overheated and and dumped all of the coolant out of the radiator, but it did not go out the overflow or blow the rad cap. I replaced the thermostat and it fixed the problem for a while. For the past week or so it had been running at about 215-217 which is hotter than I like it to be. Just yesterday it was getting pretty hot but not in the red so I pulled over and turned it off and when I looked at the engine it was water falling coolant again, the over flow level did not change level and the rad did not blow, it was just pouring coolant somewhere out of the bottom of the radiator. I waited for it to cool off enough to where I could open the rad cap and then I added coolant and distilled water and driver home, on the way home the temp kept dropping to below 150. I drove this morning and the temp never got above 140 and their was a little bit of coolant on the bottom of my radiator. I don’t have a clue what’s going on. I think it might be a bad thermostat and a hairline crack in the radiator. What do you guys think?
