Did I install the inner piece upside down? This picture is from the bottom. The arm with the slot is offset a little bit, and I assumed the biggest gap would be between the arms. When everything was tightened down, there was no gap at all between the arms.
I need to know whether or not, it’s on backwards, and then the easiest way to remove the outer arms. Thanks.
