I've had this 2001 Jeep Sport 4.0l 5-speed 82k miles for about a year now and the whole time it's made this noise if I hit the gas a little too suddenly/early.
Seems to happen if I press the gas suddenly while the wheels are spinning down or if I'm just off the gas slowing down for a red light and hit the gas when traffic starts moving before I get there.
Originally I tried changing out the transmission mount, motor mounts, which did tighten up the feel of the overall ride, didn't fix the issue.
Recently I decided to really look and try to at least narrow down where the noise is coming from exactly. Had the a** end jacked up and in gear and I could recreate the noise! Well after getting down there it's very clearly coming from the transmission/bell housing area.
Took the rear driveshaft out and the sound was non-existent.
I don't know if it's related but even just shifting into gear is usually accompanied with a similar sounding metallic clunk and can feel it through the gear lever.
Switched to Redline MTL and smoothed it out a bit but still real noisy crunchy shifts and the worrying clunk noise hasn't changed a bit.
Here's some video of the said sound:
Jacked up rear end
Sound from inside cab
Jacked up rear end
