Friends,
At least a couple times a day when I go to start my Jeep, the engine won't turn over. All the usual dash lights come on but the starter won't engage. Then I turn the key back and forward a second time, and it starts.
My thinking is the ignition switch actuator is failing. So I picked up a Dorman replacement actuator. Should I also replace the ignition starter switch while Im in there? If the pot metal isn't cracked on the actuator, could it still be the culprit? It always starts the second attempt. Only once did I have to attempt it three times till I got the engine to turn. Btw, always fires right up when it does engage.
FYI-new battery, tight and clean terminals, all as of March. Been having this funny issue for a while, even before the new battery.
Any advice or info is appreciated.
