My woes here started several weeks ago, had to replace the Ignition Cylinder... After that the Ignition switch went, along with the Ignition pin actuator....
This week, the starter started acting up intermittently, till it failed all together... Testing it by jumping power to it, the Solenoid would engage, but not the starter. So I replaced the starter (With a new Solenoid) It started up just fine... Until I drove it - Once I drove it and stopped it, it would no longer start, not even giving the click of engaging the solenoid.
I was able to jump the starter motor to the battery and start the Jeep to drive it home. Now I cannot seem to find the source of the problem. I have replaced the starter relay, ignition switch, ignition pin and cylinder, starter, solenoid, etc. and I turn the key I get dash lights, but no start.
Is it possibly as simple as I knocked a connection out somewhere when working on it? I tried tracing the cables and I don't see any "Pluggable" connections, just the 2 bolt on connections at the starter. Any help would be appreciated!
