In need of new shocks
Mayojeep
Toledo, Ohio
Hello all. I have a 97 TJ with 33” tires and a 3 inch body lift. I believe the suspension is all stock
As of right now I am in need of new shocks but eventually want to end up with about a 2” suspension lift. Ideally I’d like to piece it together over time.
I am interested in the Rancho RS5000x and am wondering what else I will need immediately to make these work with stock springs.
Any and all advice is greatly appreciated.
The shocks are sold for certain ride heights. I have the Ranchos and really like them. I think what you are looking for would be the ones for 0-2" of lift. These would be able to be used with the 2" lift springs when you buy them.
Two other non-related things: One, the 3" body lift will generally be frowned upon around here and two, my wife is originally from Toledo
Reactions: Mayojeep
Thank you for your feed back and honesty. It had the body lift when I bought it last year and looked into having it removed. As I was told by my local Jeep specialist “you are better off not removing it”!
And hello from Toledo to you and your wife.
Did he give you a reason that you would be better off not removing it? I assume because of the 33" tires, but I would order the Rancho shocks, lift springs, and a solid puck 1" BL all at the same time. that should fit the 33's. If you have a socket set and jack stands, that could easily be done on a Saturday or Sunday with some friends and a few beers.
Just tell the wife it's an early Christmas present from Santa.
