First off, I have factory 3.73 gearing in my 2000 Sahara and the correct speedo gear installed in the transfer case. The speedometer needle overreads by approximately 3.5mph at all speeds. The difference is not a percentage; i.e. it's always off by the same amount whether I'm going 20mph or 70mph. (The TJ does have a very slight 1% overread in addition to this, which is normal and to be expected).
I've used an OBD-II scan tool at speed, and the computer's speedometer is nearly dead on with a GPS. The odometer is similarly accurate. It's only the speedometer needle that is off. I assume I have to live with this as I have for the past 2 years, but does anyone know of a fix short of replacing the cluster? Would flashing the ECU do anything?
Chalking it up to a Jeep Thing, but curious if anyone else has had this problem.
