Would there be anything wrong with replacing the steering stop bolts and replacing with ones without a welded stop nut to increase the steering angle? I can reweld the new stop nut if it's advised.
I'm finding plenty on adding washers to stop rubbing but I'm not having that issue.
I have plenty of clearance at full lock with the stock steering stops, wondering if I can increase my max steering angle, or if the steering box isn't meant to go that far or some other issue I could run into.
I will make sure I can steer at the full angle at full flex, etc. if it can be increased.
