Press a dimple in the heat shield at the contact point. The exhaust mount bracket can be bent toward the transmission also.
Is it not possible to operate the rubicon lockers from that onboard air system? Or is that only with aftermarket lockers?The UCF bracket takes up a lot of space. I copied these instructions.
https://wranglertjforum.com/threads/tj-lj-rubicon-factory-locker-compressor-relocation.17449/
The locker pumps are in the lower lefthand corner of this picture. Doing it this way leaves room for other stuff.
I think you can do either but the factory lockers take a good regulator, they only take a fraction of the pressure compared to aftermarket stuff. Most people just use the stock little pumps.Is it not possible to operate the rubicon lockers from that onboard air system? Or is that only with aftermarket lockers?
Yes, raising the belly would affect the DS length.So if a person was going to buy this, as well as a SYE\DCDS, would this affect driveshaft length measurements or would it matter at all?
Thats what I would do. TW has a fairly quick turn around if thats the route you go. I got mine 3 days after ordering it.So it seems like the smart thing is to swap the skids when installing the SYE?
Could go aluminum right?Easily twice the weight of the stock skid. Stock is around 35#. I have the Ultra high clearance steel and it weighed in at 77#. On the up side the weight is down low.
Not Necessarily. UCF's no BL skid may put Transfer case output at the same height as factory.Yes, raising the belly would affect the DS length.
On the 97-02, mines an 01, it raised it less than an inch. Since the 03-06 models have a more dropped stock skid it should raise it up more. My guess is 2" or so but I haven't installed one on a late model TJ so I'm not positive.Not Necessarily. UCF's no BL skid may put Transfer case output at the same height as factory.
Yep, re-drill or elongate the holes in the shroud and reposition it.Funny thing this has popped up so many months later-
My LJ is not my daily driver. I do usually have it out at least once a week, but during the winter I may skip a week here or there due to weather.
Decided to drive it to work yesterday. The Jeep started right up, but had a funny noise- sounded like the fan hitting the shroud. Popped the hood and found the top two screws holding the fan shroud to the back of the radiator loose. I tightened them up, restarted the engine, and the noise was even worse. Looking at everything, it looks like the fan is hitting at the 6 o'clock edge of the shroud. I know raising the transmission changed all the geometry, but seems strange for an issue to appear this long after replacing the skid.
I guess the easiest fix is to lower the shroud?
X2. I had the same issue with the no body lift skid and just elongated the holes a bit.Yep, re-drill or elongate the holes in the shroud and reposition it.
The stock exhaust fit perfectly on my TJ.My old tj had a belly up skid. It required quite a bit of work to install and get rid of the vibes.
It had a lot of lift, rubi t-case etc.
I was actually looking at the UCF aluminum No body lift skid to replace the shovel in my LJ.
Did you have to mod the exhaust in any way?
