Where is it leaking at?
I just replaced the output shaft seal on mine. I called JB and they said it was a National Seal # 472572. I got one at NAPA for I think $22, and another one at Oriellys for $23.
I would replace it only if it is leaking. I was able to slide the housing off/on without damaging the seal the first time.Should you replace the output shaft seal “Once your in there”? Or only replace it if it leaks? I’m going to be doing this soon.
Thanks !I would replace it only if it is leaking. I was able to slide the housing off/on without damaging the seal the first time.
It’s leaking towards the bottom of the two halves. Was a light on the rtv., rush job on my part, daughter wanted to go to the park.Where is it leaking at?
My leak is not seal related, it was installer issue.. hahaNot to replace the seal, no. You can use a puller to remove it and then gently tap in the new seal.
