Intermittent Airbag & 4WD dash lights
hear
Can't type
Lifetime Supporting Member
Prosper, TX
Had this problem for a minute now, finally remembered to post about it. The 4WD & airbag lights will sometimes flicker on/off, and sometimes just be on. All in 2WD of course. It had been working fine, and I haven't touched any wires. Doesn't mean the jeep didn't decide to touch wires though. They do this independently of one another. No other odd things happening anywhere.
ideas?
Years ago my airbag light would come on and stay on . Ultimately , it was a weak connection where the instrument panel docks to the dash electrical connections . For fun , when the A/B light is on try hitting the top of the Gauge panel on the right top side . If it goes off , the likely cause is the connections. Pull the gauge cluster , clean the contacts , and slightly tweak the pins to ensure a tight connection. It worked for me and has been good for over 10 years .
Reactions: lBasket
this is probably not the answer but in another car I had a bunch of cluster lights acting weird and it ended up being a bad relay - you probably already knew that though
