It's been about 6 weeks since I finished dual axle swaps, replaced all steering components, swapped lift, MML, and generally rebuilt the underside of the Jeep. All ball joints and bushings were replaced in the process. I'm still in what I consider the "building confidence that I didn't forget something important" stage - short trips, no interstate, keeping it under 40.
On the way home from a 20 mile-or-so drive last night I noticed that the Jeep was pulling slightly to the left, which it hadn't been doing since I got the pinion angles worked out and did an alignment about a month ago. Maybe it was my imagination, but it seemed to get slightly worse as I continued to drive home. Then when I got to a light it pulled hard to the right under braking. I drove the last mile or two playing with that: gentle pull to the left under power, and harder pull to right under braking. The pull under braking was so noticeable that I could idle forward 5-10 feet, hit the brake hard with my hands off the wheel, and watch the wheel turn 20 degrees to starboard.
Any thoughts on what to check/adjust/tighten/replace/curse at?
