1900 is lugging the engine, not too mention 1200-1300. Hell, idle is about 800.
A couple things come into play. You have to get beyond "getting it back to stock rpm's." It is no longer stock with 33/35 inch tires. They are much heavier, wider, and need more than "back to stock" gearing to keep forward momentum. Plus you are going to be lifted, so you make the "block" we drive even worse.
The 4.0 can run at 2600-2800 all day without a sweat and do very well efficiency wise. Why did Jeep run such high ratios (3.07, are you freakin kidding??) is partially to meet EPA requirements. Not necessarily mpg, likely more for emissions. More rpm's generally mean more emission output. That and many people think 4.11 is low. Mention deep 4.XX gears and many question you; say 5.XX and they think you are nuts. We used to build a bunch of Toyota 8" back in the day and 5.29 to 5.71 were the recommendation. Those guys loved 36" Swampers/Cepeks on the little 22r/5 spd/8" diffs.
To add: scrap those "charts" that are floating around. Again, they are strictly mathematical calculations to get back to stock rpms and in whatever is the 1:1 gear, overdrive is not taken into account.
Well with larger tires the math makes perfect sense. I have stock 28" tires on right now and will be going to 30" tires soon. I imagine that my 3.73's would only be a little outsized by the 30" tires? Or maybe they are just perfect?
