2.5 all the way.
No mickey mouse BS.
2.5 springs...
4 new shocks of appropriate added length...
Sway bar links of new added length...
Make sure to get the ones that disconnect!!
Done!!
The stance...
A customer's Jeep...
31x10.50-15 tire
15x8 with 3.75 BS wheel
2.5 inch lift springs (don't remember mfg)
New shocks (I think Rancho)
Sway bar disconnects
That's it.
Works better on road than stock...
Works light years better off road than stock...
Do NOT skip the sway bar disconnects.
It's comical the number of customers we get with a pile of money in a lift only to ignore the sway bar disconnects.
Some just have new but longer ones...some ignore altogether and have a mess with the old being too short.
The suspension works wonderfully when you allow it to actually work. The sway bar links if connected allow a tiny bit of travel only. It's absurd.
We just had a WJ (99-04) Grand cherokee in...(basically same suspension design as the TJ) with this decent lift, expensive shocks, new control arms...
and solid sway bar links!!!
All this available travel but can only use a couple inches due to the sway bar links.
The above said....
You've asked this question a bunch all sorts of times and ways.
You're over thinking this.
Get some...
2.5" springs from Rough Country for a 6 cylinder (RC springs are fine)
I KNOW YOU HAVE A 4 CYLINDER and that's the point. It will give you a nice level ride with no rake.
Do NOT get RC shocks. They suck.
Get Rancho 5000x or skyjacker Black Max
If you can swing it get JKS disconnects. They're more expensive than some but the ease of disconnecting is wonderful and you'll be glad you spent a little extra. If you ever fought with cheaper disconnects you'll be so happy you got some better ones.
That's it.
Install...
Adjust your drag link adjusting sleeve to center your steering wheel...
Go wheeling already brotha!!!
