As I continue to chase down my TPS problems I can't help but suspect it might be ground related.
Is it ok to splice in a new ground wire to the current ground wire ( black with a blue stripe)
near the TPS and run this to the firewall ground?
I would also splice in a ground into the same wire near the computer and run that to the battery ground.. inside the wiring harness I observed about 4 of the same color ground wires being spliced together into one ground wire by the factory. they must go to different sensors throughout the system.
Any thoughts? Bad idea?
while I do have continuity in the TPS ground wire from the sensor to the same wire as it goes into the computer plug I still suspect maybe there is a bad ground or an occasional fault to that ground.
I did wire in a temporary ground and drove the vehicle 15 miles with no problems at all and then when I made a left turn I experienced the same TPS problem with the check engine light coming on again. (I had cleared the error codes before driving) I pulled over and found the temporary ground wire I had hooked up had come undone.
This may not be my only problem but I'm thinking at least it would rule out a bad ground.
I'm showing error code p0123 and p0121. I have been researching both of those codes extensively here.
I also have my clock spring unplug during these tests.
thanks
thanks
