I looked at the remote oil filter adapter shipped with the new engine yesterday. The adapter screws into the threaded nipple on the front cover, then the adapter has the feed and return line ports facing vertical. If the supplied hoses are threaded into the ports, the lines will stick down further than a spin on filter. A 90 degree JIC fitting would fix the issue, but I am not sure of the thread pitches at this point. The thread pitch is different for each port, one port is coarse threads and the other is fine. My short filters showed up today and I hope they will work without issue. They are only about 3.5 inches tall compared to the filter shipped with the engine that is over 7 inches tall.
