As you may remember I had gears done about 3000 miles ago. I was out a couple of weeks ago and got the TJ pretty twisted up in a ravine trying to get out. Anyway I heard some sounds from the old girls underside I hadn't heard before. Popping, and such. After I got out I looked her over good, and drove around a bit to see if I had broken or bent something. Nothing. Drove home, no problems. About a week later I see some gear oil in the bottom of the knuckle coming out of the axel tube on the right side. Cleaned it and saw nothing until about a week later and it was back. Talked to the shop who did the gears and he said it could be some "situational" leakage. In other words, I could have put enough load on the axels to cause the seal to distort long enough to leak a little oil. I've never heard of this before. It may have lost about 2 tablespoons of oil, maybe a little less. While they said they would stand behind their work and replace the seal, he asked me to clean the area and monitor it to see if it is still leaking. I drove her up on a tire lift on the left side to tip her over a bit and see if it was still leaking and it doesn't seem to be. Have you ever heard of this before? Let me know your thoughts, thanks.
