No drain plug. Gotta crack the diff open and reapply RTVRemove the drain plug, drain oil, reinstall drain plug, remove fill plug, fill with oil and reinstall fill plug.
Assuming you have a Rubicon 44.
What diff cover do you have? A pic would help a lot here.I have a fluid pump from harbor freight that works great. I am just wondering how the heck to get the top bolts off the cover to clean and re-apply rtv.
Just the same old stock one.What diff cover do you have? A pic would help a lot here.
While effective taking the diff cover off also allows you to inspect the gears and get out any fine metal that may have settled at the bottom.I used a pump I got somewhere. Plastic with knob and rod to a piston. (about the size of a soft drink can) 2 clear lines on it...one suction and one discharge..stick suction into fill hole and shove to bottom of case...hold it there with something (at the bottom) then pump the old liquid out. Clean the pump by pumping just a little new oil thru it...then pump the case full 'till oil is running out of the fill hole.....whammo !!!!! The diff. lube is changed !
