LittleGiant TJ Enthusiast Supporting Member Joined Aug 20, 2023 Messages 227 Location Honolulu, HI May 21, 2024 #1 Is it possible to have any noise, clunk, vibration, rubbing, etc from the front drive shaft without having 4WD engaged?
freedom_in_4low I'm a rooster illusion Supporting Member Ride of the Month Winner Joined Sep 26, 2019 Messages 8,716 Location Arcadia, OK May 21, 2024 #2 LittleGiant said: Is it possible to have any noise, clunk, vibration, rubbing, etc from the front drive shaft without having 4WD engaged? Click to expand... yes, it still spins when you're in 2wd because it's still engaged from the axle end. Reactions: xXDavidCXx and LittleGiant
Cooper Smith No longer have a Jeep :( Supporting Member Joined Aug 2, 2023 Messages 608 Location Amherst, Ohio May 21, 2024 #3 LittleGiant said: Is it possible to have any noise, clunk, vibration, rubbing, etc from the front drive shaft without having 4WD engaged? Click to expand... Yeah. Older trucks, like OBS Fords, have hubs that you engage. We don't have those. Some people that are geared pretty low will use engagable hubs to eliminate vibes on the road.
TJ4Jim TJ Expert Lifetime Supporting Member Joined Dec 9, 2015 Messages 3,915 Location Brookings, Oregon May 21, 2024 #4 LittleGiant said: Is it possible to have any noise, clunk, vibration, rubbing, etc from the front drive shaft without having 4WD engaged? Click to expand... Your double cardan on the front driveshaft may be ready for a rebuild (angry sparrows) and you can remove the driveshaft for safety purposes Reactions: Murf926 and Grant Lasson
JKP TJ Addict Joined Aug 20, 2020 Messages 1,653 Location Warner Robins GA May 21, 2024 #5 If the double cardan is acting up, don't mess around with it. If it seizes, it will split your tcase in half. Just pull the front shaft out until you get it fixed. Reactions: Murf926, rouxbicon, Grant Lasson and 1 other person
