So regardless of how you wire the lights, in the end the circuit must be seperated? I see, I thought it was seperate because on the YJ the third brake light doesnt flash at all during hazzards and it has its own wiring (grey and white).
But that makes sense, is that "multifunction switch" also what controls the switchback between the fender and flare marker light?
Yes. Since currently, your turn signal and brake bulbs per side are one and the same, you can’t just install the euro tail lights. You need to disable all brake input going to the multifunction switch so that with the euro lights, the amber turn signals never light up when you hit the brakes. Which then means, you have no brake output in the back (except for the existing third brake wiring of course), so you either need to splice your two main brake lights into the third brake light (since they now need brake-only input), or you need to run the wire you cut to the multi function switch and extend it out to the two brake lights if you don’t want to add onto the third brake wiring.
Nothing controls the way the fender and marker bulbs work, that’s just how they happen to operate due to the way they’re wired:
The front bulbs are dual filament bulbs that use 3 wires:
-parking lamp power (low brightness)
-turn signal power (high brightness)
-ground
The side marker bulbs are single filament bulbs that utilize two wires, normally power and ground. However, the two wires are spliced directly to two power wires. The side marker is hooked directly to the parking lamps power and turn signal power of the front lamp….
When you are driving during the day and do NOT have the lights on, and decide to use the turn signal, the side marker receives a power supply on the signal wire. The side marker bulb seeks ground through the other wire (parking lamp power wire), and runs through the front bulb’s low brightness filament to find ground through the front bulb socket. So, the bulb blinks with the front signal.
When you turn on the parking lights, the side marker gets a power source from the front bulb. The side marker bulb seeks ground through the other wire (turn signal), and runs through the front bulb’s bright filament to find ground through the front socket. So, the bulb is lit constantly with the front parking lamps.
When you have the parking lights on AND turn on the turn signal, things go backwards. The side marker bulb is already seeing a power supply on the parking lamp wire, and it’s seeking ground through the turn signal wire as mentioned above. When you turn on the turn signal, the side marker is now seeing power from both sides, which means it’s no longer grounded. So every time the turn signal lights up, the side marker dies, turn signal blinks off, side marker goes back on. So that is how it works and why they alternate when lights are on.
This side marker bulb setup is called “floating ground” because the ground ‘floats’ between being seeked through the parking lamp or the turn signal wire.
