When I put my 2000 tj on the road this spring I had done the brake lines,calipers,pads and rear brake spring kit. I had not replaced the rear pistons.No abs. Everything till now has been great for 5,000 miles. Brake pedal hard . Now as I sit I notice the pedal start to slowly go down. No leaks anywere. probably the master cylinder I suspect. Anyone run into this?
