Is there a particular year of the LJ that is best to build?
Is there a difference in electronics, buses, and any other things in the '04-06s?
If you are planning on an extensive build I'd get a non-Rubicon, whatever the year, and put the money saved into your build.Is there a particular year of the LJ that is best to build?
I know man- that dislike is well deserved- if I’m off base tell me - but I have had more CEL issues with that year model than the rest I’ve messed with combined.This is what the dash of most 2006 model Tj / LJs looks likeView attachment 324809
Driver's seat forward why is 05/06 LJ any different or more troublesome than same year TJ. Thought mechanicals and electricals in dash and engine bay were the same.I know man- that dislike is well deserved- if I’m off base tell me - but I have had more CEL issues with that year model than the rest I’ve messed with combined.
My post said both models- they are both a CEL waiting to happen - mainly because the emissions are designed to be replaced and most of us don’t want to bite the bullet and buy 4 sensors and pre cats and do it right is one reason. They have a finite lifespan.Driver's seat forward why is 05/06 LJ any different or more troublesome than same year TJ. Thought mechanicals and electricals in dash and engine bay were the same.
Ok. Missed that. ThanksMy post said both models- they are both a CEL waiting to happen - mainly because the emissions are designed to be replaced and most of us don’t want to bite the bullet and buy 4 sensors and pre cats and do it right is one reason. They have a finite lifespan.
the dislike is due to the exaggeration of "most"I know man- that dislike is well deserved- if I’m off base tell me - but I have had more CEL issues with that year model than the rest I’ve messed with combined.
“Most “ of the ones I’ve had thenthe dislike is due to the exaggeration of "most"
You'd think they would be, but Chrysler is among the worst with little changes every couple years trying to find ways to save a few bucks per part.Driver's seat forward why is 05/06 LJ any different or more troublesome than same year TJ. Thought mechanicals and electricals in dash and engine bay were the same.
Thanks. I thought that there had been some changes. This is good to know. The more knowledge before buying is always helpful.05-06 took a lot of hits from Daimler cost cutting efforts and had some issues with ecm, ignition, and fuel tank. It's all fixable but 04s don't have the issues. The tradeoff with 04 is that they all had automatics. If you want a manual trans you're stuck with 05-06, which was the 6 speed that can have its own set of issues with being noisy and popping out of reverse.
Thanks. I was already planning to do this. At some point it will be an extensive build.If you are planning on an extensive build I'd get a non-Rubicon, whatever the year, and put the money saved into your build.
I am about to start a build on an 04 and the first thing we are doing is swapping in a NV3550 with all OEM parts.05-06 took a lot of hits from Daimler cost cutting efforts and had some issues with ecm, ignition, and fuel tank. It's all fixable but 04s don't have the issues. The tradeoff with 04 is that they all had automatics. If you want a manual trans you're stuck with 05-06, which was the 6 speed that can have its own set of issues with being noisy and popping out of reverse.
This will be the Boss Lady's Jeep so it has to be an automatic. Looking at puting a 10R80 behind a 351W.Go '04. Less problems that '05 to '06, but as @freedom_in_4low said, they're all automatic.
'04
OPDA - still can affect '04 but not as many - fairly easy to fix from what I've seen, if done preventatively though. Crown makes a replacement OPDA.
PCM - I don't believe these issues affect '04's but someone correct me if wrong - also think it's a fairly easy fix https://wranglerfix.com makes replacement PCMs for 05-06.
Or just get an '04 and don't worry about either one.
others mentioned issues above RE: trans.I will try to snag a '04 but it will be the one that has the best body when we get it. At least there's a fix for the problem.
