Is there a torque spec on the belt tensioner adjuster 1999 TJ 4.0
99greenTJ
Okla. City
Is there a torque spec on the belt adjustment bolt? 1999 tj 4.0?
If not anyway to gauge enough tension?
Per my 1998 FSM:
I didn't know the needed numbers or I'd have posted yesterday but checking the tension of the actual belt instead of the adjustment bolt is what I figured should be done.
For some reason I was kinda thinking about twisting the serpentine belt between pullies but maybe that had something to do with my VW timing belt a couple decades ago.
Thanks, this is the first car I have serviced that didn't have a spring loaded type adjustment.
Forgetting about those 50's, 60's, 70's cars, I have worked on!
Hey! For a 1999 TJ 4.0, the torque spec for the belt adjustment bolt is 30-40 ft-lbs. If you don't have a manual, you can use the deflection method: press down on the belt with your thumb and aim for 1/2" to 3/4" of deflection.
Correct I just changed the belt on my 1999 4.0 with AC. Used the 30-40ft-lbs and the belt would occasion squeak on cold start. I gave it a few more spins and all good now.
I just assumed that torque spec was for the 15mm bolt holding the pulley assembly to the adjustment rod.
That much torque on a belt seemed a bit much?
Good to hear real world experiences.
I bought an expensive Burroughs gauge for serpentine adjustments. I found that that cranking down the adjustment rod to get the factory TJ spec's resulted in a super tight belt likely to destroy bearings. The old rule of thumb (literally) applies. Moderate thumb pressure halfway between pulleys for 1/4" deflection. 35ft lbs is correct for the pulley bolt to lock it down and the idler pulley.
Reactions: 99greenTJ
