I'm assuming you already replaced the foil heat shield that fits under the fuel rail?
Those are cheap insurance against heat soak and cost around $4.00 average.
Photo of heat shield :
https://www.partsecatalog.com/chrysler-cbxcb060
You can also insulate each individual injector by using spark plug boot/wire insulators.
They come in various styles and would need to be trimmed for length. It might require you pull your fuel rail in order to slip them on, or you could split them and wrap around and secure. You could even split several lengthwise and wrap around your fuel rail itself for a little extra insulating effect.
I've included a link and photo to one that Autozone sells, and the same brand has other part numbers listed on Autozone's site.
Autozone Thermo Tec Spark Plug Tube Insulator
Part #14200
http://www.autozone.com/ignition/sp...silver-spark-plug-wire-heat-shield/398830_0_0
A link to a YouTube video showing someone experiencing similar heat soak and what they did:
